Indesit innex xwa81252 washer (warning lights)
19 Jan 2007
Kent
Hi all,
The above machine stops after about 1 minute, door lock light goes out, then all the lights flash.
I’ve switched it off for a couple of minutes as in the book, but it goes though the usual motions when reset, door lock light on,starts as usual, after a couple of minutes the door lock light goes out, then all the light flash.
Is this pointing to the door lock being faulty?
TIA
I have but it says flashing lights but with door lock light lit, not without it, try reset by turning power off for a minute, tried that still the same, nothing about the door lock light being off? Thinking maybe door interlock playing up?
Found the fault, took the door interlock switch off and found the plug to the switch burnt, the switch was discoloured but ok, found one of the connections to the plug loose and fell off when I took the top off the plug, so I’ve cut the plug off, made separate connections for each wire to the switch,and it’s back working, so far so good.
