Turn the cold feed off to the boiler and try bleeding or draining the rad.
If nothing comes out someone’s got egg on their face lol!
Has the rad been cold since the preheat on the boiler was switched off?
Is there any difference now the pump is set a little higher? Don’t forget there is still another 50% or so power left in the pump you could turn it up all the way on max and min to see what effect that has. I wouldn’t leave it like it because you’re likely to have noise issues with the flow through the rest of the system.
And finally get the damn gas pipe sorted!!!
Yes I came out to you the other day re the hot water lol!
