Need a new fire, what type though...?
1 Mar 2008
With a recent house purchase, I have inherited an old, knackered, gas fire "Cannon Coalridge category 1N fire (GC# 3213258)".
I am having major work done on the house, and, as part of this, I am having this fire replaced.
Basically, I need to know if this is a type 1, type 2, balanced flue... etc etc fire/chimney, so I can buy a suitable replacement fire, can anyone advise please?
I'm (obviously!) not doing the job myself, I just need to know what to order for my gas engineer to fit.
Thanks,
Colin
as far as I remember the Canon Coalridge was a balanced flue gas fire , is there a terminal on an outside wall behind the fire ?
Thanks for the replies, please find some answers below;
@45yearsagasman no probs, I'll take some wider pictures on Monday and add them here.
@ianmcd, no, there's no wall mounted terminal, it is connected to the chimney that leads to the roof.
Thanks to everyone who has responded, but I'm none the wiser, not knowing a lot of the terms being used... B/F (balanced flue I would guess), O/F (??) etc.
I think for now I'll get some more pictures and add them to the tread.
Will this do the job?
https://www.flames.co.uk/fireplace-...ERYeQHAdUDKx5DtJXptVJPWh-OKcWurBoCvzkQAvD_BwE
This is supplied with either a "Class 1" or "Class 2 fire", so is either suitable? And which one should I order?
Thanks again,
Colin
You would be better to have your gas engineer in to have a look, he should be able to tell you pretty quickly what you need. He may also test the chimney.
Alternatively it would be advised to have a chimney specialist in to check/sweep and smoke test it. If it's an old Class 1 then the mortar can go porous and would need to be lined and terminal'd/sealed top and bottom properly to ensure it's safe.
Too much to take a chance with IMO as an open flue'd LFE can kill quite easily.
Fire selection should not just be a visual thing as lot of these inset fires are quite inefficient. When selecting a fire, look at the heat input and the heat output. 7kW input and 3.5kw output will give you a fire that is 50% efficient.
Aim for 80%. Outset fires are more efficient, not fashionable, but wipe the slate when compared to fire in your selection
Hi, please find below a couple of pictures of the fire as requested.
One thing I did notice is that it is not fixed to the wall in any way, and can be lifted away from the wall of the fire-place, outwards into the room...!
Does the rectangular bit at the back look like a balanced flue - I'm not sure.
Thanks,
Colin
That's an open flued appliance fitted into what appears to be old fire opening. There will be a chimney above it outside on the roof. Only an inspection by a RGI will confirm the flue is ok for a new fire.
Thanks, yes, I'm going to get my RGI to have a look before buying anything - I may end up with a new electric fire in the end... haha.
It's a surprise to see it like that though, I would have assumed that the flue should all have been sealed.
I'll let you know what the outcome is - thanks everyone for the help.
Cheers,
Colin
