Bonding/Multi Mix or Overboard?
1 Sep 2011
Essex
I've never overboarding a ceiling, only skimmed over artex. However this ceiling had coving which has been removed and made a bit of a mess. The result is some sections flaking off and some loose material.
Would you
A: remove loose material then PVA, to bind it all then mix of bonding/skim, then skim OR
B: Overboard with 9.5mm PB and skim?
Ok so I've bought 12.5mm plasterboard for overboarding and in the process of marking out joists. Bought a magnet to find where existing nails are then was going to use a chalk line to mark a line across the ceiling to know where to screw.
I have seen people use a hammer and break holes in the existing ceiling near to the joists to locate the exact centre's but surely thats not a good idea with the potential asbestos in artex?
Also if you are working alone is it a good idea to cut 2400mm boards in half for easier lifting into place? I realise it's more screws/scrim tape but surely thats easier?
You don’t need to knock holes, you can just drill with a small size bit, you’ll feel if it’s going into a joist or not. Then mark centres and ping chalk line across.
Yeah I can’t board ceilings with 8x4s on my own, I use 6x3s.
Ok will do a small drill hole either side. Already got a magnet to work out where they are roughly and have just bought a chalk line. Have made a support too and seen that it is a good idea to screw long screws into the wall near ceiling to use as a another support for the board.
