Hello
Would appreciate if someone can double checking my understanding here please before I make changes.
My garage has a consumer unit powered off the house CU via a RCD. Within the garage there is a single light fitting (fluorescent) which is on a loop from the garage CU via a wall switch.
I would like to add a second light which is itself switched via a pull chord. The second light should only work when the wall switch is on.
I opened the flourescent fitting and I noticed the switched live (neutral with red tape) is connected directly to the red live. That confused me a bit, because the actual light fitting doesn't seem to have its own switched live. Presumably this means the switched live is energising the live (black with red tape, to red) which then loops via the CU to the light fitting?
Is the correct way to add the second light fitting simply to add a new twin and earth to the light fitting choc block?
Mike
e
Mike
e
