No, cause when u press the black button with case off it still doesn't work
Is it the switch that doesn't work or the solenoid coil?
The switch in your pic is stuck in the " on" position. Nothing wrong with the solenoid ( different part altogether)
That's the on / off switch. If your shower comes on / works fine when you turn on the external switch ( is it ceiling pull cord type ,or wall mounted)?
How kind of them ,Mira said they sent me the wrong part twice and will refund me.
Ordered it.This one looks the same, just pop the black switch out of the housings and swap them over
https://www.showerdoc.com/redring-o...nEY5gl5eNBPCpnB2_oLFEg3rbaMVVuhUaAodvEALw_wcB
