Replacement manual TVR help
17 Aug 2004
Hi guys,
My old system had Honeywell HR80UK CM Zone RF TRV on every radiator (22).
I know know have Hive and don’t need the HR80UK’s but want to replace them with manual ones.
As the existing valve is the push down type (sorry don’t know the name) is there an adaptor I can get to put a cheap manual one on them? It’s more for aesthetics than anything.
Thanks for any advice
Are you able to remove the head and see what’s left? If so upload a photo, I haven’t had any dealings with these myself.
I will do later it's basically what you are left with is a pin which is sprung, up open and compressed closed.
  • Thanks
Reactions: CBW
Thank you so much Muggles These look perfect!
Yep I know what you mean about downgrading, if the old system did not fail so often I would not have changed, it's an odd layout here but these will be fine to balance out some rooms
