I’m trying to work out how to add a double socket to a ring. I want to either spur off a surface mounted metal clad socket which is near the floor or extend the ring. It is in a church hall and the main reason to extend it is to allow for electric kettles and such to be easily used on tables as people tend to use extension leads which have all sort of dangers like tripping over them. I’d rather extend the ring as the power used on the new double socket will be fairly high. Two kettles will draw 6kw, about 26 amp, and I’d rather have plenty of capacity.
I am thinking of putting in a new metal clad double socket at tabletop height with a single length of 20mm plastic conduit linking the two socket boxes. Can I put a terminal block behind the existing socket and run three singles up to the new socket, and three singles down to the existing socket? All 6 singles would be in the same conduit. I could run two conduits but wonder why I would need to. The terminal block is accessible as it is inside the box, behind the socket. I’m sticking with metal clad as they are not perfect but do withstand the odd hit by a football better than plastic.
I suppose I am asking two questions.
1. Is it OK to extend a ring by using a terminal block inside the back box?
2. Is it ok to run both legs of a ring in one conduit?
