10mm plastic to Euro Rad Valve
1 May 2018
Hi all,
I am trying to order a combined rad valve with 50m pipe centres. The Milano web site offers odd sizes such as 14mm and 12 mm but not 10mm. Am I missing something?
I just need to order a euro valve that will connect to 10mm plastic.
Another question is can I use a brass reducer 15mm - 10mm with plastic pipe?
I was being cheeky I think you meant 50mm between centres and not 50M, and if you look at the link you posted all tappings are 1/2" female thread so any standard 1/2" to 10mm valves will fit
I intend using a valve with TRV and lock shield in the same body. The TRV adjustment is horizontal. The inlets are 50mm centres. I’ve used some left over 10mm pipe from our kitchen underfloor heating. Push fittings work but standard PEX pipe inserts are too small and I’m concerned that the reducing set won’t work in any 15mm valve.
I have dismissed the eurocone option now.
