replace double dimmer with normal switch
t78
29 Nov 2008
Essex
hi,
we have a double dimmer switch in the conservatory that I'd like to replace with simple switches.
it is wired as per the attached photos.
IMG_20200125_155624327.jpg IMG_20200125_155653036.jpg IMG_20200125_155702183.jpg
do I need to buy any special kind of 2 gang switch?
is the wiring straight forward to swap to the new switch?
many thanks.
No special two gang switch is required. The Termination points might be labeled differently but it should be easier enough to work out how they go once you have your New switch. Buy that and if you have issues post an update for help.
