Rising Damp - long term solutions
i've had a chance to look at the pdf's - who provided the diagram?
the standard of the reports is par for the course - there's a bit of confusion and contradictions here and there but they get the gist of things across.
i presume that the Survey was your private survey not a mortgage survey?
why was the D&T external survey done in the dark?
1. confusion about the floors - are they all cracked concrete floors?
2. which floor is recom for replacement? switching to colleagues can be a way of softly bumping up prices.
3. D&T survey shows no pics.
4. the diagram should have been annotated.
5. one chimney breast and one c/stack is claimed but there appear to be two c/breasts and stacks present?
6. the C/H flue terminal popping through the flaunching is too close to the solid fuel flue open pot.
7. open redundant flue pots need protective cowl inserts.
8. boiler is mentioned but no pic.
9. dry rot was noted and then almost dismissed - the dry rot could be under the floor slab and in the wall. more investigation needed.
10. stone cladding noted without comment - its a well known source of penetrating damp.
11. no mention of cavity insulation - was loft insulation mentioned?
12. hardly any attention was paid to the bathroom and, most importantly, the kitchen?
however, the property is what it is, and some money spent, and a bit of hard work will have it ship shape in no time -
on the basis of the reports dont be afraid to buy the place. go for it if you want it.
Somebody's going to make some money out of that place.
I'd guess it will be bought cheap by a builder or developer. New roof, remove the chimneys, dig up the floors, find and rectify the source of damp, bish bosh, sell on.
Maybe add a chalet floor in the roof.
Harder and more expensive for a homeowner lacking the skills, time and determination.
Maybe even sell it as a site for redeveopment and put up four new rabbit-hutch homes.
Sad to see a home that's gone downhill, presumably due to age and infirmity of previous owner.
If there's a water meter you can verify my suspicion of a water leak under the floor. Châtaigne, mon cul.
By the diagram do you mean the floor plan?
Yes, the survey was a private one, we don't know why the D&T one was done in the dark, we have done some research and have found positive feedback from the work carried out by this person, we have asked to speak direct to him if possible
To answer where i can;
1, All floors are concrete, hall (laminate) Rep1 and Rep2 are carpeted (not lifted) kitchen and bathroom are lino. Dining is exposed but sound screed. Bed1 & 2 have what looks like vinyl tiles, with exposed spalled concrete around the perimeter in places - i will try and find a picture to show this.
2, Bed1 & 2 and kitchen are recommended for possible replacement
3, Correct, there were no pictures with this report - unknown if they were held back from us
5, We had to check this ourselves, stack in Rep1 (front) is external from ground to eaves, we initially thought it had been removed internally
6, Its now a redundant flue - a mistake on the surveyor's report. The boiler flue exits the kitchen external wall
7, Agreed
8, Brand new Worcester Greenstar 24 Ri boiler is fitted
11, Loft is insulated "Currently there is approximately 150mm of insulation installed. The recommended depth is 270mm"
12, Apologies, I removed the parts regarding the kitchen & bathroom, there is a double unit with a working sink in the kitchen. The bathroom is the stuff of a B horror movie, c/w stainless steel shower tray. The toilet flushes, that the only positive!
Thanks!
I think it was marketed too high to fall under a developers radar, by the time you'd pumped that amount of work in, you'd hit the ceiling price for the area, id said was day 1 it was over priced, but we are not looking at it from a money making front, it will be a long term investment for us. In over 2 years of searching its the only place that we have found that's got positive potential. Its big enough to house all the equipment needed for our daughter, to allow her a better quality of life as she gets older. Plus its one of the few that has ticked the councils hoops that we have to jump through.
I cut my teeth on a 1890's end terrace that ive done a total restoration on, is was certainly a learning curve. Its a good job i like a project.
Id imagine its got no water meter, but i appreciate the advice and will check thoroughly for any internal leaks and wont be ruling anything out. I suspect there are buried water pipes in there, just from looking at the current kitchen/bathroom layout
Off topic but have you any idea what the car in the garage is?
After looking through the survey I think this explains why the vendors downed tools after the boiler install. Are they relatives of the deceased? Hopefully you can use the above to negotiate a serious price reduction to conduct the repairs. £10-£15k should get it sorted but I assume it will be a money pit so the spending won’t stop there
Its fiberglass shelled, possibly midget based - i wish id took pictures, im guessing its not seen daylight for a while!
Its the Son who has inherited the property, we get the impression he had nothing to do with his parents as there are certain features (the bizarre substantial metal framework in the garden) that he has no idea what purpose they served.
based on the info so far: some of these items are almost Mickey Mouse stuff - dont sweat the schedule of works .
the heavy lifting jobs wont take more than a few thousand, and kit and bathroom standards are up to you and your pocket.
if the sale goes through then come back on here for further suggestions about how to proceed.
I
Bomb shelter ?
Nothing there sounds unusual for a building of that age.
Looks to have loads of potential, if I was up that way I'd want it!
