A cupboard in my bedroom used to house a water tank
Following removal of the tank, I would like to use the empty space as a wardrobe.
Currently, the cupboard space has a redundant switch with a fuse.
After removing the switch, the wire used is 1mm two core and earth.
I also know that the switch is on a separate curcuit on my consumer unit and in terms of overcurrent protective devices the amp rating is 6
What I wanted to know is whether i could
1. Replace this fused switch with a regular switch
2. Install a downlight in this area?
