Worcester Bosch 28i - leak right hand side
31 Oct 2008
Midlands
Hello
I had the left hand control block replaced in Jan. Now I have a leak coming from the right hand side.
How easy would this be to fix - I presume an O ring has failed. Plumbers are difficult to get hold of around here....now impossible with the virus!
Attached a couple photos which may help. Any advice appreciated.
Thanks.
Looking at it - it's a straight forward job. Question now is.....does anyone know the O ring size before I open it up ?
I don’t know the size, what I do know is: removing the boiler cover without undertaking essential checks afterwards is frowned upon.
More likely to be the whole plastic section rather than an O ring and you shouldnt really be doing that yourself, as already advised
  • Thanks
Reactions: CBW
The Green rubber deflector below the inlet manifold is a clue as to how common it is for a leak to manifest there ;)
