Danesmoor 15/19 Oil fired boiler needs bleeding
Thanks Guys, after being a bit of a twit and letting the tank run empty :whistle:, I have managed to follow the above instructions and get everything working again. Not bad for an old bird. I have even thought ahead and taped the right sized allen key to the side of the boiler. One thing I would say is that if you fire up the boiler and the bleed screw is loose, the kerosene will miss the strategically placed container, spurt out at speed and leave you smelling like an arsonist.
( so i am told:cautious: )
Thanks again (y)
J
Help! Same problem, however trying to bleed the P plug is impossible to turn!!! Wont move! Could it have been glued and another way installed to bleed?
