Mine has ceased working, the lights are on but no movement from the motor. The last time this happened about 7 or 8 years ago I found the brushes were worn and replaced them, this time they are OK though.
It has been suggested that the door switch is faulty although I have dismantled and cant see anything wrong but I don't really know how it works, its complicated. the switch contacts open and close when operated manually but there is a voltage drop across them of just under 0.6 volts which seems to suggest the have diodes in the circuit.
The switch is the old type retained with screws rather than pegs.
Any suggestions?
Thanks Peter.
Any suggestions?
Thanks Peter.
