Wilo Gold 60 CH Pump Replacement
24 Mar 2020
Evening,
My CH Pump is 20 years old and sounds like it is pumping gravel now. I think replacement is in order. The old pump is a 3 speed wilo gold 60 which is discontinued. What would a good modern equivalent for this be? Are there any makes/models to avoid? Any that are particularly good?
I’d possibly go with a Grundfos, reliable and decent brand. Ups I think the newer ones are called.
New type Wilo or near identical different branded pumps are also good it seems.
Doubt if any of them will last 20 years though. Might be very lucky to get 10 years perhaps. Too complicated these modern devices.
6metre head pumps are same as your Wilo 60, but you will have the option of fixed 3 speed settings of variable speed settings (which will vary the power used when rads and circuits close).
  • Thanks
Reactions: CBW
