- Joined
- 4 May 2020
- Messages
- 8
- Reaction score
- 0
- Country
Hey guys
I have a logic system s24IE boiler which has a leak on the ch flow pipe fitting below the boiler
(see pic attached)
I would be fairly handy DIY wise so I went at it today and did manage to suppress the leak a small bit by really tightening the nut. The thing is I think it needs a need fitting. I shut the water off at the mains and I also turned of 4 valves in the hot press which normally turns water off going to taps and bathrooms etc. However as I went to loosen the nut on the leaky fitting water started pouring out for a good few minutes so I’m unsure I’ve done the right thing in shutting the water off going to that pipe. If I could get the water off properly I do think I could replace the fitting myself. Any ideas? I’ve a vented cylinder in hot press.
Alan
(see pic attached)
Alan
