- Joined
- 26 Nov 2017
- Messages
- 100
- Reaction score
- 10
- Country
Hello chaps,
Our old bathroom fan of 72m3/hr died a few days ago so I've replaced it with a Vent-Axia Silhouette 100T, which has an extraction rate marginally higher at 108m3/hr. The bathroom is in the middle of the house with no windows and no external walls.
Unfortunately, the builders used uninsulated flexible ducting which exists through a vent on the outside of the building (about a 5m run) that is installed slightly higher than the fan itself.
The ducting is completely unsupported and runs off at a tight right angle from the fan, before (I assume) turning a further right angle for a run of 4m to the external vent. Due to the way the pipe runs, I don't think the previous extractor fan ever worked correctly. I always thought it was poor, but since everything else in the house is too, I never looked too closely. Apparently, it was because the back draft shutters would have been unable to open. The new one was the same, so I've had to remove them for the moment. It does extract now, but, we have condensation dripping from the fan, which I guess I expected.
Without cutting a huge hole in the bathroom ceiling or removing a glued down chipboard floor in the bedroom above (which is on ijoists so would be very invasive) I can't access the pipework at all to attempt to install any supports or ideally rigid pipework. There is no space in the void above the plasterboard ceiling to fit a condensate trap and nowhere to drain one anyway.
I've never noticed condensation before, but if the back draft shutters were unable to open as I suspect, then I guess it wouldn't occur with the old fan since warm air isn't meeting cold air?
External vent is straight through and not a louvred self closing type.
Given the above, is there anything at all I can do to help the situation that doesn't involve cutting large holes anywhere? I'm trying to minimise that kind of thing because I've found electrical runs all over the place in the en-suite upstairs and I've no reason to think the rest of the house would be any better.
I'd be most grateful for any pointers.
Thank you.
Thank you.
