Hi all
I'm in the process of replacing a basin monobloc tap with another.
The previous had copper pipe going to the tap which connected to an isolation valve and then to a Flexi pipe.
The new unit has Flexi pipe from the tap which I need to connect to another piece of Flexi pipe. What is the best way of connecting? Would an isolation valve work or is there something with two flat ends that would work better?
