I'm replacing a panel of flooring and looking into what glue I should use. I have some PVA glue but seen there is D4 spec at a higher price and thinking if it is worth it? Its only one piece of flooring and studwork is going over the top of it. Will double bead the joists and noggins and then apply a bead on top of the tongue once connecting up with the other board.
thanks
thanks
