Vertical radiator TRV position?
Also flush it through before you hang it. These Rads tend to block and part of the rad doesn't get hot.
It's the swarf that's produced in manufacturing.
Where do these go ?
If you turn your valves so that the heads point up, you can then insert the male end in the bottom of the valve facing the wall then then the 15mm copper tube pushes in the push fitting.
Don't use chrome pipe.
These are John Guest fittings.
brill
thanks
