Aviary roof
15 Mar 2004
Leicestershire
I have an all metal aviary the breeding area is constructed of flat sheet metal and it is getting so hot in that area I have thought of putting another roof on top of the leaving a gap between the new roof and the original roof would anyone have any ideas of what materials I should use
Any material you use will get hot, you could try laying a sheet of celotex on the roof and weighing it down with bricks to see if that helps as it is reflective.
How big is the roof?
Drap a large towel/dust sheet weighted down, then hose the sheet down every morning until the hot weather has passed. It won't be long.
Andy
If you put your lining or spacer inside the aviary, it will not need to be weatherproof.
yes but you will then have to lay a weatherproof roof on top of it. It would probably last for this summer otherwise.
I suppose Shed Felt would do. It is "mineralised" with green grit which I think is supposed to make it last longer than the old tilers' felt.
Felt roofs don't last very long.
There may be some sheet roofing material, maybe a white corrugated, that would do better.
If you are not bothered about aesthetics then you could just weigh the pir down with some old bricks.
