Hi, hope someone can help!!
Moved into our first home just over a year ago. When we purchased we had a full structural survey which highlighted that some work was required on the chimney. Including work to the render and possibly replacing the flashings.
Had a roofer out not long after purchasing the property and he repointed the chimney stack and replaced a broken ridge tile and installed new lead work.
Then I have noticed that in really bad weather water is appearing on the chimney breast in the attic. We have a chimney sweep grate and after looking in there can see that water appears to be coming in through the top. We live near to the sea and the weather can be very strong!
We would like to use the chimney in the future so don’t want to cap but are looking for a solution to stop the rain entry. There are some caps already on the pots but unsure if they are sufficient.
I have attached some photos to try and make more clear and to show the work that has been completed. Any help or advice would be appreciated as want to try and get this sorted! Thanks in advance!
