If the scope of an EICR can be significantly reduced (for example by only testing some, but not all, sockets on a given circuit) why it can it not be extended to include - at the electricians discretion - problems that manifest themselves, such as the damaged cables?
As I have said,
anyone can commission
any electrician to undertake
any sort of Inspection and Testing (with
any scope) they want done, but that I&T would then probably be something other than "an EICR" ("full" or otherwise). This is therefore really a fairly pedantic terminological discussion, stemming from the initial suggestion that a "full EICR" should be undertaken on the building that RF mentioned.
BS7671 says very little about such inspections. For a start, it does not use the term "EICR" (abbreviated or in full) at all, other than (I would say reasonably) as the title of the report which is produced - it refers to what we are talking about as "Periodic Inspection and Testing". It says nothing specific about scope, the nearest it gets being "
A generic list of examples of items requiring inspection is given in Appendix 6." (which is simply example forms for the report, together with associated notes. For what it's worth, whilst it talks about 'limitations' of scope (to be agreed in advance by the person commissioning the report, and recorded on the report form), it says nothing about 'extensions' of scope.
To consider the realities, the hidden cables of virtually
any electrical installation could be suffering from extensive rodent damage which (as in RF's case) would not be identified (or event suspected) by a "full EICR" - and, indeed, that would very probably have been the case (and 'everyone would be happy') had a "full EICR" been undertaken the day before RF discovered the cable damage.
When some such cable damage is found (and even if electrical testing reveals no problems), the ideal is obviously to expose all the other cables in the installation to see if there is any other such damage - but, as I've said, in some cases (like my large house) that would not really be practical. However, I think the main point is that, once an electrician has tested the insulation and found no problems, that additional 'ideal' inspection is not something that requires an electrician, or is really appropriate as part of an 'electrical inspection'. It requires no electrical skills or electrical test gear to lift floorboards and look for visible signs of cable damage (that is not detected by electrical testing) - that clearly doesn't require an electrician, and to pay an electrician's 'hourly rate' for doing that would (in my opinion) be a little silly. That's why I said at the very start that, if it were me, I would probably
myself lift at least a few nearby floorboards in an attempt to get a feel for the extent of a problem - and then, depending on what I found, decide "what next?".
Kind Regards, John
