Cheap trap? Some are known to leak... Try a McAlpine, better quality. Also check it's not coming from above, how have you sealed the waste into the basin?
Waste to basin is siliconed. Not from there- I have spent ages lying down and wiping dry and checking where the leak is. No leak on the threads of the waste. It is a Floplast cheapie from Screwfix.
