Recently had our UPVC back door replaced and when they took out the old door frame they broke the concrete threshold/step that it sits on.
The top of the threshold where the door frame sits is fine, as is the whole of the outside face. The damage is all on the inside.
Its entire at one end for a small distance (so we could fix shuttering to that) but then broken off at an angle down to the floor at the other.
We're fitting 50 ml PIR insulation with a floating 18mm chipboard T&G (2.4 x .6) floor over the top, so we need to sort it. The 68mm will still be slightly below the top of the threshold, and the inside edge sits slightly back from the internal wall perimeter since we've insulated the walls so we could put some ply shuttering in line with the wall at one end and the existing entire front of the threshold at the other end.
There's no heating in the room ATM but we do have a portable electric heater. What's the best compound /mix to use? It's probably 100 mm x 600 mm max.
