Annoying bath waste
5 Feb 2005
Put in a new freestanding bath wifey decided on.
The plug is a "push" thing with built in waste.
Every time I have a bath I sit on the plug, which depresses and drains water.
The waste overflow is a horizontal bar, rather than a round one
Lile the pic below (which is a random exanplez not my bathroom)
Can anyone suggest / provide a link for better waste, that will fit, that doesn't depress each time you have a bath... I can only find wastes with round overflows
Cheers
I had a look and reckon I can keep the overflows as is.
So I guess my revised question is:
Can anyone recommend a bath waste that wont depress when you sit on it?
I dont have enough exposure to them to know what to look/ask for. The one I have protrudes up, domed, like mushroom, so really easy to sit on / depress.
Is there a bath waste that sits flush so you need to push it down with fingers?
Apparently a traditional plug on a chain is not acceptable
So who is using the ends of the bath whilst your sitting over the plug.........:D
Before I order, bit of advice if anyone can offer?
So I need a slotted waste. There are 2 of that style available.
I hope that the connections are all standard, as the rectange overflow on the bath is attached / inaccessible, however, the overflow pipe connects to the existing waste is.
Will either of these be suitable, or, preferable? Will the first just be a direct swap/standard thread?
Dont want to buy one, dismantle the bath and find it wont fit!
https://www.victorianplumbing.co.uk/clearwater-click-clack-bath-waste-slotted-cw1
https://www.victorianplumbing.co.uk/click-clack-bath-waste-with-overflow-bwc02
For reference, the one to replace is this
And no, they are not my toys...
Show us a pic of your actual bath. If you do not have access to beneath the bath you can't change the waste.
Your overflow and waste may be a combined unit ,and not interchangeable.
Apologies - I am going senile. Just lifted the bath and there's not a waste pipe. Its a combined unit.
I unscrewed the thingy and it looks slotted like the second one
So i reckon the second one? Or am I stuck with this mushroom?
Thank you for your help
Not come across any baths that need a slotted waste! They all go via a ribbed hose into the bath trap IME!
Tomorrow Ill lift bath again and take pics.
Nine of the above is visible - all sealed behind a fiberglass shell.
Looks like I can just unscrew the waste and put a new one it. The existing one is slotted, you can just tell from the photos.
