- Joined
- 17 Dec 2020
- Messages
- 5
- Reaction score
- 0
- Country
hi guy's, i'm a spark to trade so don't know much about alarms, i'm doing a bench test on the above alarm before fitting and have come across a problem ,when i use the user code then press p then program 2 everything works as it should, when i disconnect 1 of the zones that is inhibited the alarm sounds, if i use the omit button then press the zones i require everything works even when i remove the links, why does the alarm sound when i remove the links in the inhibited setting. thanks in advance
