It’s nice to do things correctly though
Makes a difference to the ringers on some phones. I knew this argument would start
The only time I can recall the polarity changing during a call was when it was used as a signal to lock the coin slot on early call box phones. What is is used for on domestic phones?It shouldn't make any difference as the polarity of the line does alter during the call.
If the polarity affects a phone, then the phone does not conform to appropriate approvals.It’s nice to do things correctly though
It's not used for domestic phones but it was used within the switching network EDIT: and the line polarity reversed during every successful call, well up as far as Crossbar, TXE2,TXE4, System X & System Y. [I left BT in1994]The only time I can recall the polarity changing during a call was when it was used as a signal to lock the coin slot on early call box phones. What is is used for on domestic phones?
Yes but now it's called [and is] something else.Are there still any shared service party lines out there?
It's not used for domestic phones but it was used within the switching network, well up as far as Crossbar, TXE2,TXE4, System X & System Y. [I left BT in1994]
I do believe you are basically correct Sir. Why did you mention it?System X and System Y digital exchanges did not have the facility for party lines ??
You said it was used in Sys X&Y, remember them outdating the 'party lines' I saw parties old earth clamped between houses and questioned what it was for as I was Cable TV and phone, not BT. I saw a lot when I worked in Birmingham. (94-96)
It's (Polarity changing) not used for domestic phones but it was used within the switching network EDIT: and the line polarity reversed during every successful call, well up as far as Crossbar, TXE2,TXE4, System X & System Y. [I left BT in1994]The only time I can recall the polarity changing during a call was when it was used as a signal to lock the coin slot on early call box phones. What is is used for on domestic phones?
