Not a sparky, but always heard that there should be no visible copper in connections.
Green and yellow is mandatory - not merely preferred.The switch only needed drying out on the radiator.
Blowing it with a hair dryer for 5 minutes would probably do the same.
When you do refit or fit a new switch, cut the exposed copper down to about 8mm max, what you have is way too long and it exposes live copper.
Try and out some sleeving on the earth wires. Green/yellow is preferred but anything is better than nothing.
Bi-colour combination of green and yellow ONLY.Green or, preferably, green/yellow. May be a sleeve or even pvc tape but should not be any other colour or you may cause confusion at some later date.
Green would not suffice. It is expressly forbidden by BS7671.As I said, preferably green/yellow, but if the only other colour he has is green then it would suffice. Better to have a correct 'old' colour than the completely wrong colour or nothing at all. No-one is going to be prosecuted for using the old colour coding.
Now you're an electrician, your plastering needs work, though! Good on yer for DIYing though. Learning to plaster is fun
At least in England and Wales, there is nothing "mandatory" about anything in BS7671. I can't speak for other countries.Green and yellow is mandatory - not merely preferred.
I said nothing about electrical knowledge. I merely reminded people that nothing in BS7671 is 'mandatory' (at least, in England and Wales), and I would have absolutely no difficulty in explaining that to a judge, since it is an undeniable fact.Good luck explaining to the judge how your electrical knowledge and expertise is greater than the combined knowledge of the British Electrotechnical Committee (BEC) and the Institution of Engineering and Technology (IET)
and the colour of sleeving on a CPC is certainly not an issue that would ever get tested in court.
You may choose to interpret it in that way, but I was merely pointing out a factual inaccuracy.Well the only purpose in that statement is to imply that the regs can be ignored, and any bad consequences are unpunishable
