I think when radiators are sized for a central heating system, the size of rads required for each room would differ depending upon whether the system had a condensing or non-condensing boiler.
I'm not sure if the radiators should have greater output capability if its a condensing or non-condensing boiler? Would be interesting to know.
Whichever boiler type requires rads of greater output capability, I presume it would be possible to use the larger output rads irrespective of which boiler type is used?
If so, presumably its an idea to install the larger output rads, in case the boiler is changed from one boiler type to the other?
Thanks.
Thanks.
