13 amp fused spur for plinth heater
2 Dec 2019
Im looking to install a plinth heater in my kitchen and the booklet says it needs a 13 amp fused spur.. there is a double wall socket behind the oven that's not currently in use..... can a 13 amp fused spur be run from the double socket in order to power the plinth heater......or can i put a 13 amp plug onto it and simply plug it in?
What Rating?
I should think a Plug should be ok but would mean removing the Oven so not ideal but not like you'll be unplugging and plugging it in every day.
