tried the two types of plasterboard fixings-
Easyfix self drill and hollow wall anchor fixings
With the easyfix self drill the screws were so stiff going in then then when in plasterboard the whole thing screw and other bit started turning. How can you prevent this?
With hollow wall anchor ones worked great with a gun.
Do you check plasterboard thickness by going slow and feeling push through? Pushing screwdriver through hole to check for pipes?
