Long Drill Bits.
You must drill a 5mm shank hole through the first bit of timber, or the joint won't tighten up.
You shouldn't need a pilot hole with decent screws.
Are your fence posts oak or softwood.
Use wax on screw or even spray WD40 into you screw box....lubrication helps a lot.
No, length of bit driver makes no difference apart from access.
Thanks all. Used a PZ3 and got much better results. So thanks all. Now furnished myself with a set of DeWalt PZ3s.
