Compliance with IP rating on consumer unit
27 Nov 2010
Warwickshire
I've added a circuit to a consumer unit, the cable didn't fit through the existing hole, so I knocked a new in the top. In order to ensure it is IP4x, can I just use electrical tape to seal it? And if not, what product would you recommend? I don't know the name of the plastic thingy that goes in the hole that the wire goes through so I'm not sure what to search for!
I know it's a noddy question, sorry!
If you've added a circuit to a consumer unit and you don't know a gland is called a gland, I'm assuming you won't be testing and notifying these notifiable works?
Edit...is this the SWA from your earlier post that you've brought into the CU? If so, it needs glanding properly such that the armouring is earthed.
I won't be inspecting and testing it myself no. But I know it needs it and will get it done.
It's not the SWA. I've terminated that correctly I believe using a CW gland, including the banjo and earth fly. This question is for adding a circuit with standard 2.5mm t&e.
All good then. If you are gonna get it tested by a 3rd party its way easier if you involve them beforehand.
I used stuffing glands, as to new circuit, it seems a little vague as to what is considered new, so if I want a socket local to consumer unit, and I fit it to the existing ring final overload, then not a new circuit, it is an extension to an existing, and if I then decide I want it on it's own overload, and move it across it again is not new, clearly there should be a minor works raised for both jobs, giving the paperwork trail, and clearly circuits which are altered should be inspected and tested, but the new circuit may tell the electrician when a compliance certificate is required, but for owner/occupier it means nothing.
Clearly with rented property you need the paperwork, be it minor works, installation, or EICR, the paper trail is very important, but with owner/occupied who would know if paperwork not raised. Clearly it needs inspecting and testing, before it is energised, but as to paying the LABC for a completion certificate, it may be legally required, but only time I did it correct, they never even visited the house, it just came through the post, and when I tried to get a replacement they said it would take 4 months, if they can find it, and charge depends on how much time they spend finding it, in other words the whole completion certificate is no more than a tax.
