- Joined
- 13 Jan 2021
- Messages
- 15
- Reaction score
- 0
- Country
Turn off supplies, disconnect flexi's from rigid pipework, I'd then fashion a shower hose or something to the open end of the hot supply then turn supply back on, check that runs clear and flow/pressure is as expected. Remove flexi from tap body, blow/look through it to ensure clear, reassemble, restore supplies. Check operation and for any leaks. If pipework is clear and situation doesn't improve, then probably new tap time.
Thank you I will try tomorrow
