Menvier TS700
14 Jan 2021
I have a TS700 menvier control panel- I have managed to purchase a
SD1+ control panel the broken one I need to change hasn’t got the + will it be compatible for a straight change over if I just copy where the wires go?? Also how can I change it without setting the alarm off, when I went to open the cover the anti tamper went off??
pictures may help understand what your looking at on both units so you can be advised accordingly.
as with most panels enetr engineering before opening up panel, if you dont have it try the default one, if that doesnt wiork you should be able to silence the tamper with a user code.
Thanks so much for your quick response and help, however,I’ve taken pictures of both keypads, but haven’t worked out how to put them on here‍ ‍♂️ Right, i think I’ve put the
Photo of the old and new control​
You will need to look at the SD2 and the SD1+ manuals there are difference in the board when looking the units up and a jumper to change the polarity of the triggers.
so there maybe slight difference, not familiar with the product.
The SD2 dialler has a red button and up and down arrows instead of letter doh!
Now I’m a tad confused, yes, it makes sense that SD means speed dialer ‍♂️
But it’s phsically the same size and shape, the button layout is identical, so, I thought it woul be ok, the buttons match, the LCD looks identical, I wonder if I could swop the buttons and screen to my old one to get me going again- how complicated would it be, I’m wondering? Thanks again for your comments
......errr .....no
Ok had a good look and found this ....unable to test as I don’t have a control panel to test on but it lights up 6514EA3C-3854-4D3C-B3AB-6E21EB31FC17.jpeg1739EFBA-9AA4-4275-81BE-B7529A3C98C0.jpeg
