Neff electric oven
8 Jan 2021
Hi
I bought an Neff electric oven (B45E743GB).
I have wired it up and it comes on. I have set the clock.
The problem is I cant get the oven to come on. The temp display does not come up either. I feel I may need to press some buttons together and then the actual oven will come on. Once the oven comes on the temp will be displayed.
Any idea what I am doing wrong.
I have attached picture
No the instruction booklet just says setting the clock. Accordingly to the booklet, once clock is set you should be ok, but i feel i am doing something wrong and that's why oven does not heat or the temp display is not showing
where the temp display is i get " c32 & c10", not sure what this is?
I think C10 says you are in the settings menu, and C32 sets the timer alarm duration to 2 minutes. normally enter settings menu by holding info button for 3 seconds
