Ford Fiesta MK6 (2007) Help identifying this cable please
6 Feb 2021
Hi all,
I have just changed the starter motor on my Fiesta MK6 and whilst removing the old one, this cable came off. There is only a limited amount of movement as its housed in a cable tidy with little stretch. I've had a good look round above and below the engine but I can't see anywhere obvious it may have come from. Please can you help identify it?
Thanks.
J.
It’s the sort of connector that pushes onto an oil pressure or water temperature sensor.....often these things have a screw thread which grips the connector there.
Nothing like that in the vicinity?
John :)
Thanks for your replies. I found the location just behind the oil filter so I was happy to get it reconnected. Thanks again!
