- Joined
- 8 Mar 2010
- Messages
- 255
- Reaction score
- 0
- Country
What ho one and all,
The area of Surrey where I live has now gotten sufficient Gigabit government vouchers to have the full fibre installation, probably later this year.
At the moment, I have not signed up, but am giving it serious thought. However, I have a number of questions that not surprisingly, the answers cannot be found on the internet, nor can anyone else answer.
The fibre would be coming overhead, presumably to the loft, where the current BT line comes. I did not install CAT5 when I built and only have the regular phone cable throughout the house. X years ago, BT 'moved' the master socket from the loft to the g/f office by reconfiguring the existing cables, but did not actually install anything new. At the moment, both our desktop computers are wired into the router which is plugged into the master socket.
I would like the computers to be plugged directly into the new fibre router, but as I understand it, this means the ONT would have to be on the wall of the office. Is this correct?
Or can the ONT be in the loft and the existing telephone cable allow the router to be plugged into whatever socket in the office, where it already is located?
I am told 'they' will install the fibre where I want it. What does this mean? If I want it in the office, will they bring the cable from the loft, down the external wall, around the side of the house and drill a hole through my air-tight timber-frame wall?
I have used my mobile phone to check the wi-fi signal. Next to the router, I get a network speed of 72Mbps but in the loft, only 42. What does this imply if I were to use wi-fi with a fibre connection?
Thanks and toodle pip
Rex
Rex
