worcester greenstar utility 18/25 oil constantly locking out before it runs.
I am having problems with the oil burning boiler again. It is locking out all the time and has been for few weeks.
The boiler will sometimes fire and run but more often than not it won't fire at all - tries for a few seconds then stops. Reset button might need to be pressed 4 or 5 times before firing, some days better than others.
Have had the jet replaced and the photocell replaced.
Baffles and tank cleaned.
Filter on oil tank is less than 1 year old.
Plumber has checked/ adjusted the C02 reading etc .
I replaced a coil on it a few years ago but the symptoms were different - would get warm then stop. This has problems just starting.
Is it worth replacing anyway?
What else can I try.
