I'm really struggling to get this right. I've done a mock up which seems to work ok but I think the tray should be lower? Between the battens, but then there's nowhere for the water to go. Should I make up some tilting fillets instead of the bottom batten?
The tile height seems ok at two battens, assuming they should be parallel on the top faces? I'm worried that the tray will end up above and behind the gutter rather than in it.
