I need a bit of a steer on the best way forward if anyone has any ideas. I'm planning to put a fence up in our small mid-terrace patio garden after having the area tiled on top of a new concrete slab as part of renovation works last year. I need to support fence posts whilst getting them as close to the party walls & back corners as possible, to minimise loss of space in the garden.
Seems that best practice for concreting in a 4" fence post is a 12" x 12" hole with the post in the centre (ignoring just for now the issue of potential rot with putting posts directly into concrete, etc) - however this would mean bringing the fence in quite a bit on all sides and losing a fair amount of garden space in our tiny garden - particularly at the narrow flower bed at the back, so I'm looking for another solution.
The tiled concrete slab goes right up to the party walls on left & right sides, apart from the back wall where we've left a 70cm deep soil section at the back for the fence and bamboo / flower planting. On the right side with the higher 5ft wall I'm planning to fix the fence posts directly onto the wall. On the left side with the low 2ft wall I'm looking at bolt-down brackets fixed directly through the floor tiles and into the concrete.
How tight I can get the fence to both sides though, hinges on how close into the corners I can get the back fence posts. I've dug a small trial hole in one of the back corners down to about 2ft to see what's happening with footings etc, and it seems to go down fairly straight, so in theory the posts could go quite tight into the corners?
Is it advisable to set fence support brackets into concrete for example, and is there such a thing as an offset one designed for concreting in?
Any suggestions?
TIA
Any suggestions?
TIA
