Uneven founds
You are probably correct in cost for materials.
Its the labour cost saving and not working in a hole that makes trench fill more appealing.
Was told trench blocks would b cheaper than pouring concrete to fill trench
I’m laying them myself so no labour cost. Just messed up with one side of trench
Ive just had the same problem with my extension self build.
Laid the foundation mostly flat but one edge had a 25mm rise along it and also the level of it was out of line with the bricks on the house it was joining to. I spent a day or so cutting the first course of concrete blocks to take into account the foundation rise and to get everything lined up with the house on the first row. once I'd laid them every subsequent course just lined up fine and no adjustment was needed other than the slight issues with the house not being built to gauge or level!
Does it matter if you have a 20-30mm bed of cement to lay the first row of blocks on?
If you're not building a skyscraper I'm sure a short section of 100mm strip on good ground will be fine, especially with 3 or 4 courses of trench blocks on top. Use sharp sand instead of building sand for thick beds.
