Blocks
11 Mar 2014
Yorkshire
Just starting an extension build and plans state
7.3n insulite blocks, trying to get these specifically in a hurry is proving difficult but been offered plenty of 7n concrete blocks.
Apart from .3 n is there any difference that I’m missing
U-Values and weight.
I can recommend the Plasmor Aglite which looks to be similar:
Aglite Ultima | Plasmor - Blocks, Concrete, Architectural Masonry, Paving, Aglite, Expanded Clay | Plasmor
Lower U-Value, and slightly lighter too.
A normal concrete block is waaaaaaay heavier and not as thermally efficient
Your spec sheet is here:
Insulite Standard Datasheet - November 2020 (thomasarmstrongconcreteblocks.co.uk)
You need a Thermal Conductivity that's the same or lower
Thank you
