Indeed, as I said, I thing 3/0.029" was the norm for lighting.Come to think of it, I think the old imperial lighting wires did have three strands.
True, I should not have mentioned black - they would probably both have been red.Presumably the old switch drops would consist of two or three of these red and green cables. I don't think blacks or neutrals were brought to the switch, particularly around the 1960s as suggested.
Fair enough - so you're suggesting that 'switch drop' consisted of two separate cables, each consisting of an insulated-and-sleeved red 'stuck to' a green-insulated CPC? ... but did lighting cables actually have CPCs at that point in history?As I understand it, the red is sheathed and insulated, the green in only insulated, and two are 'stuck together' sort of thing.
Kind Regards, John
