Plywood on floor
27 May 2007
Essex
Hi, I have moved into an old house, the floor boards are OK but a bit old Knackered and gappy, before I put in a fitted carpet I was going to cover the floor with plywood and screw down, my question is can I use thin ply ie 3mm, is there a down side to this or should I make it any thicker.
Or would hardboard be better?
Thanks for any advice.
i put hardboard down on a couple of bedroom floors quite a few years ago, onto normal wood floor boarding , before underlay / carpet, all seemed fine, moved out of house since.
Thanks all, I'll use hardboard, should I use ring nails or screw them?
Hammer stapler/tacker is easy option. Short ring nails if you don’t have tacker.
