Naylor Lintels
25 Jul 2014
Hi
I need to get a Lintel. It is recommended I use R6 Lintel.
Those Lintels are 100 X 145mm.
But the wall is 2 leaves of 100mm, making it 215mm wide.
I am wondering, how will the bricklayer be able to put 2 X 100mm concrete blocks on top of the Lintel?
This is not my field of work, so I have no idea.
Please let me know. Thank you.
The lintels are 100mm wide and 145mm tall.
So the bricklayer just puts two 100 x 145 lintels side-by-side.
Who recommended that you use two single leaf lintels on a double wall? :rolleyes:
You should use a single lintel.
Many thanks to you all.
I will have to speak to the building engineer.
