How to make hole in shelving unit look nice
r_c
19 Jun 2016
(BTW I am not a tradesperson - I have a boring office job with little practical DIY experience.)
I want to drill a couple of holes in some shelving units, but am at a bit of a loss as to how to make these holes look nice. Or at least make them not look bad.
I want to drill two holes to feed an electrical cable through (for LED strip lights at top of unit). I found these desk grommets on Amazon which might be ok for the horizontal (worktop?) surface.
https://www.amazon.co.uk/HO2NLE-Gro...2HHN4KD/ref=pd_di_sccai_3/261-9441731-7571317
But is there something more suitable for the side vertical surface? Maybe something smaller? The shelves look great, and I don't want to mess them up with a bodge DIY hole.
Can't you drill straight into the void on the left, up from the cupboard below.
Sorry @Notch7 I should have stated that this is for an electrical cable to provide power to LED lights across the top of the shelf, and I would like to have a switch somewhere in that 'box'.
Actually I was originally thinking of an inline switch like this but maybe there is something else I could use that is nicer? The power will come from inside the cupboard and then go up a hidden gap between the shelves and the wall.
Something like these?
  • Thanks
Reactions: r_c
Run cable as Notch suggested then remote control switch for lights, all hidden.
Or plug in lights using a wifi switch , again all hidden.
