Painting previously varnished door
16 Jan 2006
Newport, S Wales.
I have an internal porch door and frame to paint probably anthracite grey, it’s currently dark varnished.
It sees no bad weather.
I was thinking of trying the Zinsser all coat paint to save on time with prep etc, has anyone any experience of it?
2nd option would be Zinsser bin and then a topcoat satin.
Any advice on which of the above you would choose?
You can save on the prep but you will have a door that is prone to chipping...
There is no substitute for sanding the surface.
The WB Allcoat Exterior Satin, is available in Anthracite off the shelf. You won't need additional primers (according to Zinsser).
https://www.zinsseruk.com/product/allcoat-exterior/
IIRC, if you need a dark colour mixed, you need to find a supplier that carries the clear bases. Many branches of Brewer do but if there isn't one near you, you can phone Zinsser and ask them which of your local stockist have the clear base.
Zinsser BIN is not recommended for exterior use, bar spot priming. To be honest, I have never understood why. I really should email them one day to find out why.
Thanks, I would lightly sand and sugar soap but just wondered about missing out the primer stage in favour of the all coat.
Sanding is essential here. Aluminium wood primer is also an acceptable primer for this job imo.
